Using Garmin Connect Training Plans
The Garmin Connect™ platform offers a variety of training plans to help you reach your fitness goals. Each plan will provide a series of workouts that build upon each other to prepare you for your event. Plan types include:
  • Cycling
  • Running
  • Triathlon
  • Self-Guided
Our training plans feature workouts and expert advice from the world's top coaches. When you find a plan that fits, add it to your Garmin Connect calendar. You can even send the workouts to your compatible Garmin device and use it as your virtual coach.
Training Plans are accessed from Garmin Connect. A limited number of training plans, including the Garmin Coach training plans, can also be accessed from the Garmin Connect app (see What Is the Garmin Coach Feature in Garmin Connect? for instructions).
Standard running training plans can include some non-run workouts like cross-training or bike workouts, but only run workouts from the training plan will be sent to devices. Non-run workouts in the training plan will only be displayed as a note in the Calendar in Garmin Connect. These notes will explain what to do for the workout, but will not be recorded like a structured workout.
Triathlon training plans will send running and bike workouts to compatible devices, but swim workouts will only be displayed as a note in the Calendar in Garmin Connect. These notes will explain what to do for the workout, but will not be recorded like a structured workout.
Scheduling a Training Plan
  1. Sign into Garmin Connect.
  2. Select Training & Planning from the navigation bar on the left.
  3. Select Training Plans.
  4. Select Find a Plan and use the options at the top to narrow options by sport.
  5. Select the desired training plan and review the plan details.
  6. Once you have found a plan you like:
    • For Cycling plans, select Set Up Plan, complete the questionnaire, and then select Create Plan.
    • For Running or Triathlon plans, input the desired start or finish date then select Schedule.
  7. Once scheduled, send the training plan to a compatible device.View those steps here: .
Editing or Removing a Training Plan
Select a platform below to learn how to edit or remove a training plan.
NOTE: Cycling Plans will not offer an edit feature in order to change or update race date or long workout day of the week. However, scheduled workouts can be edited on the training calendar. If the end date of a Cycling Training Plan needs to be changed you will need to cancel the existing plan and set it up again with the new end date.
Garmin Connect App
NOTE: Self-Guided Plans will not show up as an active plan in the Garmin Connect app. You will be able to view and edit the workouts from the calendar within the app.
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Training & Planning.
  4. Select Training Plans.
  5. Select an active plan.
  6. Select 3 stacked dots (top right).
  7. Select an option: (Cycling Training Plans will only show Remove)
    • Remove: this will end and remove your training plan.
    • Help: for detailed information on a feature in the plan.
    • Edit: will allow you to make changes to the training plan.
    • Pause: this will pause all workouts related to the training plan until you resume plan.
    • Quit: this will end your training plan completely and there is no way to reverse this selection.
Garmin Connect Web
  2. Select Training from the navigation bar on the left.
  4. Locate an Active Training Plan.
  5. Edit or Remove the training plan:
    • Select Gear Icon to edit the training plan. (Will show for Garmin Coach Training Plans only)
      • From here you can Pause or Quit the training plan.
      • There is no way to undo changes once you select Quit Plan.
    • Select Trash Icon to remove the entire training plan. (Will show for Cycling, and Self-Guided Training Plans)
    • Select Pencil Iconto change the start or finish date for select training plans. (Will show for Self-Guided Training Plans)
Specific details on how to access a training plan on a Garmin device can be found in the owner's manual
Screenshot shows active training plans in garmin connect web
Will My Training Plan Sync Over When I Add a New or Replacement Watch to Garmin Connect?
As long as the new or replacement watch is compatible with your current Garmin Training Plan, the workouts should transfer over after a successful sync. If you are not seeing them transfer to your new or replacement watch, confirm you have set the new or replacement watch as your Primary Wearable Device.
