Changing Time Settings on an Automotive Device
When your device is locked onto a satellite signal, the time syncs with the GPS satellites. Your device also has the ability to automatically update the time based on the time zone that you are in. If you happen to be in a part of the world where your device does not recognize the correct time due to a change in time zone, you can manually adjust the clock on your device.
Follow the instructions below to change the time setting:
- Touch the time that displays along the top of the screen on the main menu
- Select the correct time
- If there is a checkmark in the box next to Automatic, you will need to uncheck the box in order to change the time manually
The time will now be adjusted.
