Garmin Sonar Module Compatibility
Garmin sonar modules are devices that provide sonar to chartplotters that do not have built-in sonar capability. They also provide additional sonar options that may not have been included in some chartplotters' built-in modules, such as ClearVu or SideVu.
Select a sonar module below to see which sonar modules are compatible with various chartplotters and how they connect. See the module's installation instructions for more information about network connections.
Compatibility by sonar module
Select a sonar module below for a list of compatible chartplotters:
GSD 20
Connects using Serial Connection
    • GPSMAP 172 / 172c
    • GPSMAP 178 Sounder
    • GPSMAP 182 / 182c
    • GPSMAP 192c
    • GPSMAP 232
    • GPSMAP 238 Sounder
    • GPSMAP 276c
    • GPSMAP 292
    • GPSMAP 296
    • GPSMAP 376c
    • GPSMAP 378
    • GPSMAP 392
    • GPSMAP 396
    • GPSMAP 478
    • GPSMAP 492
    • GPSMAP 4x0 series
    • GPSMAP 5x0 series
    • GPSMAP 5x5 series
    • GPSMAP 20xx series
    • GPSMAP 21xx series
    • GPSMAP 22xx series
    • GPSMAP 3xxx series
GSD 21
Connects using Serial or CANet
Serial
    • GPSMAP 172 / 172c
    • GPSMAP 182 / 182c
    • GPSMAP 192c
    • GPSMAP 232
    • GPSMAP 276c
    • GPSMAP 296
    • GPSMAP 376c
    • GPSMAP 378
    • GPSMAP 396
    • GPSMAP 478
Serial or CANet
    • GPSMAP 292
    • GPSMAP 392
    • GPSMAP 492
    • GPSMAP 4x0 series
    • GPSMAP 4x5 series
    • GPSMAP 5x0 series
    • GPSMAP 5x5 series
GSD 22
Connects using either CANet or Garmin Marine Network
CANet
    • GPSMAP 292
    • GPSMAP 392
    • GPSMAP 492
    • GPSMAP 4x0 series
    • GPSMAP 4x5 series
    • GPSMAP 5x0 series
    • GPSMAP 5x5 series
    • GPSMAP 4xxx series
    • GPSMAP 5xxx series
    • GPSMAP 6xxx series
    • GPSMAP 70xx / 72xx series
    • GPSMAP 74xx / 76xx series
    • GPSMAP 80xx / 82xx / 85xx series
GSD 24
Connects using Garmin Marine Network
    • GPSMAP 7x2 series
    • GPSMAP 7x3 series
    • GPSMAP 9x2 series
    • GPSMAP 9x3 series
    • GPSMAP 10x2 series
    • GPSMAP 12x2 series
    • GPSMAP 12x3 series
    • GPSMAP 84xx / 86xx / 87xx series
GSD 25
    • GPSMAP 7x2 series
    • GPSMAP 7x3 series
    • GPSMAP 9x2 series
    • GPSMAP 9x3 series
GSD 26
    • GPSMAP 7x2 series
    • GPSMAP 7x3 series
    • GPSMAP 9x2 series
    • GPSMAP 9x3 series
GCV 10
    • echoMAP 50s / 50dv1
    • echoMAP 70s / 50dv
    • ECHOMAP Plus 7x / 9x series
    • ECHOMAP UHD 7 and 9 series
    • ECHOMAP Ultra series
    • GPSMAP 5x7 series1
    • GPSMAP 7x1 series
    • GPSMAP 7x2 series
    • GPSMAP 7x3 series
    • GPSMAP 8x0 series
    • GPSMAP 9x2 series
    • GPSMAP 9x3 series
    • GPSMAP 10x0 series
1 This device cannot display SideVu.
GCV 20
    • echoMAP 70s / 70dv
    • GPSMAP 7x1 series
    • GPSMAP 7x2 series
    • GPSMAP 7x3 series
    • GPSMAP 8x0 series
    • GPSMAP 9x2 series
    • GPSMAP 9x3 series
GLS 10 (Panoptix LiveScope)
    • ECHOMAP UHD2 7sv Touch series
    • ECHOMAP UHD2 9sv series
    • GPSMAP 7x2 series
    • GPSMAP 7x3 series
    • GPSMAP 9x2 series
    • GPSMAP 9x3 series
For compatibility of each different Panoptix LiveScope transducer see compatibility for LVS32, LVS34, or LVS62
Compatibility by transducer
Select the transducer mounting type:
Ice fishing
Ice fishing transducers are not compatible with sonar modules.
In-hull
Airmar M260
      • GSD 24
      • GSD 25
      • GSD 26
Airmar M265LH
      • GSD 25 (12-pin, dual-channel CHIRP only)
      • GSD 26
Airmar P72
      • GSD 24
Airmar P79
      • GSD 24
Airmar R111H
      • GSD 26
Garmin GT8HW-IH
      • GSD 25
Garmin GT15H-IH
      • GSD 25
Pocket-mounted
Airmar CM599LHW
      • GSD 26
Airmar PM265LM
      • GSD 25 (12-pin only)
      • GSD 26
Thru-hull
Airmar B60
      • GSD 25
        • Must be set to 50/200 kHz (500 W)
        • Cannot be used with the Garmin GT30
Airmar B75 (H, L, M)
      • GSD 25
      • GSD 26
Airmar B117
      • GSD 24
      • GSD 25
Airmar B150M
      • GSD 25
      • GSD 26
Airmar B164
      • GSD 25
Airmar B175 (HW, H, L, M)
      • GSD 25
      • GSD 26
Airmar B258
      • GSD 24
      • GSD 25
      • GSD 26
Airmar B260
      • GSD 24
      • GSD 25
      • GSD 26
Airmar B265 (LH, LM)
      • GSD 26
Airmar B275LHW
      • GSD 26
Airmar B619
      • GSD 24
      • GSD 25
Airmar B744 (V, VL)
      • GSD 24
      • GSD 25
Airmar P19
      • GSD 25
Airmar P319
      • GSD 24
      • GSD 25
Airmar R109 (LHW, LM)
      • GSD 26
Airmar R509LHW
      • GSD 26
Airmar SS60
      • GSD 24
      • GSD 25
Airmar SS164
      • GSD 25
Airmar SS502
      • GSD 24
      • GSD 25
Garmin GT21-TH
      • GSD 25
Garmin GT23M-TH
      • GSD 25
Garmin GT30 (TH, THP)
      • GSD 25
      • GCV 10
      • GCV 20
Garmin GT34UHD (TH, THP)
      • GCV 20
Garmin GT51M (TH, THP)
      • GSD 25
Panoptix LiveScope LVS32-TH
      • GLS 10
Transom or trolling motor-mounted
Airmar P32 triducer
      • GSD 25
Airmar P66 triducer
      • GSD 24
      • GSD 25
Airmar TM150M
      • GSD 25
      • GSD 26
Airmar TM185M
      • GSD 25
      • GSD 26
Airmar TM265LH
      • GSD 26
Garmin Dual Beam (4-pin)
The 4-pin Dual Beam transducer is not compatible with any sonar modules
Garmin Dual Beam (8-pin)
      • GSD 25
Garmin Dual Frequency
      • GSD 24
      • GSD 25
Garmin GT8HW-TM
      • GSD 25
Garmin GT15M-TM
      • GSD 25
Garmin GT20-TM
The 4-pin GT20-TM transducer is not compatible with any sonar modules
Garmin GT20-TM
      • GSD 25
Garmin GT21-TM
      • GSD 25
Garmin GT22HW-TM
      • GSD 25
Garmin GT23M-TM
      • GSD 25
Garmin GT24UHD-TM
The GT24UHD-TM is not compatible with any sonar modules
Garmin GT30-TM
      • GCV 10
      • GCV 20
Garmin GT34UHD-TM
      • GCV 20
Garmin GT36UHD-TM
      • GCV 20
Garmin GT40M-TM
Garmin GT41-TM
Garmin GT50M-TM
Garmin GT51M-TM
Garmin GT52HW-TM
Garmin GT54UHD-TM
        • 1200 kHz SideVu not supported
Garmin GT56UHD-TM
The GT56UHD-TM transducer is not compatible with any sonar modules
Panoptix LiveScope LVS12
The LVS12 transducer is not compatible with any sonar modules
      • GLS 10
Panoptix LiveScope Plus LVS34
      • GLS 10
Panoptix LiveScope XR LVS62
      • GLS 10
