Editing Check-In Contacts on the Garmin Explore Website
NOTE: null For more details, see Related.
Check-in messages are a convenient way to send messages to specific group of friends and family. There are three check-in messages to choose from:
  • Check Mark I'm checking in, everything is okay.
  • Triangle I'm starting my trip.
  • Square I'm ending my trip.
You can customize the recipient list of your check-in messages, but you cannot customize what the check-in messages say. Who the messages are sent to is determined ahead of time by editing Check-Ins on the Garmin Explore™ website. Editing any one of the check-ins will update the recipient list for all three check-in messages.
  1. Log into the Garmin Explore website.
  2. Select MESSAGES at the top of the page.
  3. Select Edit next to any one of the three check-in messages.
    Edit Buttons for Check-In Recipients Explore
  4. Enter the recipients.
    • You can enter email addresses, SMS numbers, or inReach® addresses. SMS numbers must be entered as (minus the brackets): +[Country Code][SMS number]. For more information on country codes, see - https://countrycode.org/.
    • Separate each number or address with a comma. For example: fake@garmin.com, +18008001020.
    • NOTE: There is no specific limit on how many recipients you can enter, but it is important to consider your plan's included satellite text message limit. For example, if you enter 10 recipients and they all reply to your check-in message, those replies would quickly use up the text message limit on a Safety plan.
      Edit Check-In Recipients Field Explore Website
  5. If desired, select the checkbox next to MapShare to send your Check-In Messages to the MapShare™ page.
    NOTE: This option only appears if you have enabled MapShare feature from your online account under Social.
  6. Select Save.
The recipient list for all three check-in messages will be updated. When finished, sync your device so the Check-In Messages are updated on the inReach handheld.
IMPORTANT: After editing Check-In messages on the Garmin Explore website, you may need to force close the Garmin Messenger™ app on your phone for these messages to update within the app, then reopen it.
For steps on how an app is force-closed on an iOS phone, see - Apple support - Close an app on your iPhone or iPod touch
For steps on how an app is force-closed on an android phone, see - Android support -Find, open & close apps on Android
Syncing an inReach Device
null
Adding Location to Check-In Messages
Location information can be included with Check-In Messages by configuring SMS message preferences in Account settings on the Garmin Explore website. Location data is automatically included for Check-In Messages sent to email recipients.
  2. Select ACCOUNT.
  3. Scroll down the page to SMS Message Configuration.
  4. Check the first two boxes to include location.
    Message Location Options on Garmin Explore Website
NOTE: The position format for latitude and longitude coordinates sent with Check-In messages is set to Decimal Degrees (WGS84) by default and cannot be changed.
Related
