Replacement Locking Collars for Garmin Marine Devices
Newer Garmin cables do not have the locking collars factory-installed; this allows for easier installation when routing the cables through and behind cabinetry. The two-piece locking collar is attached to the connector. Double-check, the box for the included split locking collar but if lost or if a replacement is needed, see the below list for part numbers. Refer to  Marine Cable Locking Collar / Split Connector Installation for instructions.
11mm Cables
    • Threaded Locking Collar - 010-11170-01
      • 2-pin power cable GPSMAP 4xxx and 5xxx series (verify threaded)
      • 8-pin power cable (some ECHOMAPs and GPSMAP)
      • Power cable - GSD 24, GSD 25, and 26, GCV 10, GCV 20
      • 8-pin transducer cable
      • 12-pin transducer cable
      • Small Marine Network cable
      • Power cable - AIS 300 and 600
      • GHC 101 / GHC 20 / GHC 50
      • GHP 10 ECU connections2
      • GHP 12 ECU connections
      • All Garmin Marine Radar systems1
1 check for threaded or quarter turn port. Depending on the manufacture date, all Garmin radars could contain a threaded or a quarter-turn connector. Confirm which collar is needed before placing an order
2 This only applies to GHP 10 ECUs packaged in the Reactor 40 Core packs
14.5mm Cables
    • Threaded Locking Collar - 010-11170-02
      • 19-pin power cable GPSMAP 7x0 series
      • NMEA 0183 cable  GPSMAP 4xxx 5xxx, 6xxx, 7xxx, and 8xxx (verify thread on the GPSMAP 4xxx - 5xxx series)
18mm Cables
    • Threaded Locking Collar - 010-11170-00
      • Large Network Cables (RJ 45) - including Panoptix series transducers and sonar modules
      • LVS32 LiveScope Transducer
      • Video cable GPSMAP 4xxx, 5xxx, 6xxx, GPSMAP 7xxx  (verify thread on the GPSMAP 4xxx-5xxx series)
