Map Page Orientation on the Astro 220
The Astro® 220 has two map orientation settings. You may need to switch between these options to achieve your desired map orientation.
- Track Up allows the position pointer in the center of your map to always point towards the top of the screen, while the map rotates in relation to the direction you are pointing your device, that is, your heading.
- North Up allows North to always be at the top of the map screen, while the position pointer in the center of the map rotates in relation to the direction you are pointing your device, that is, your heading.
To switch between Track Up and North Up:
- Press Map
- Press Menu
- Select Setup Map
- Highlight the General tab:
- Highlight North Up or Track Up Orientation
- Press Enter
- Highlight desired option
- Press Enter
Your Astro will now behave according to the setting you chose, as described above.
