Replacing the Buckle on a QuickFit 22 or 26 Watch Band
Garmin recommends that you take your watch to a jeweler if your buckle hardware needs to be replaced. The buckle of a compatible watch can be replaced with another buckle from a QuickFit 22 or 26 band, depending on your watch band size.
Since we offer so many color combinations, we may not offer a replacement band that offers the same color hardware as your original. Replacing the buckle should only be needed if you have purchased a new QuickFit band, and would like to use the same color of hardware that your old band had.
To replace your watch band buckle, you will need the following:
  • A clean workspace
  • QuickFit 22 or 26 band
  • Replacement buckle
  • Pair of Torx T6 screwdrivers
Select an option below to see steps.
Removing the Buckle
  1. Insert one of the Torx T6 screwdrivers in the right side of the buckle pin screw and hold firmly in place.
    BuckleReplacementStep1
  2. Place second screwdriver into the opposite side and rotate counter-clockwise until the screw comes out.
    BuckleReplacementStep2
  3. Remove the screw.
    BuckleReplacementStep3
  4. Use the screwdriver to push out the buckle pin.
    BuckleReplacementStep4
  5. Remove the remaining buckle and tongue from the band.
    BuckleReplacementStep5
Attaching the Buckle
  1. Align the buckle with the buckle pin holes on both sides of the band.
    BuckleReplacementStep6
  2. Guide buckle pin through the hole in the buckle.
    BuckleReplacementStep7
  3. Put the tongue piece in the small gap and push the buckle pin in completely.
    BuckleReplacementStep8
  4. Place the buckle pin screw in the buckle pin hole.
    BuckleReplacementStep10
  5. Use the Torx T6 screwdrivers to secure one side and screw the buckle pin screw in.
    BuckleReplacementStep11
