General Amplifier Troubleshooting
My Amplifier isn’t working.
- Check to see which, if any, LED indicator is on.
No LED
  • If neither indicator is on, first check your inline fuse in the power cable near the battery. (If blown, replace with the same rated fuse.)
  • Ensure the earth/ground and power connections on the terminal block of the amplifier are clean and tight.
  • Ensure your remote wire has a good connection at the amplifier and head unit/source.
  • Check the amplifier fuses. If blown, replace with the same rated fuse, but if they fail again you may have a problem in your amplifier circuit. Do not replace with a higher rated fuse as this could result in major damage.
  • If more than two amplifiers are linked ensure a 30Amp relay is being used going to the amplifiers.
  • If the problem persists please consult your authorized dealer at your place of purchase.
Protection LED On
  • If the red protection LED is on it may be that the amplifier has gone into thermal protection (overheating).
  • Let the amp cool down for 15-30 minutes and try again.
  • If the amp still goes into protection, it could be the result of a speaker/sub problem. To check this, disconnect the speaker/sub from the amplifier and turn the amplifier on. If the power indicator comes on and stays on, that would indicate that you have a problem with your speaker/sub.
  • If the protection LED comes on you may have an internal problem with your amplifier.
  • There could be a fault that needs professional diagnosing and servicing.
  • If the problem persists please consult the authorized dealer at your place of purchase.
Power LED On With No Sound
  • This can indicate that the amplifier is not receiving a signal from the head unit/source. You can test the amplifier with an RCA to 3.5mm audio cable. Connect the RCA's to the amplifier and the 3.5mm jack to a media source with a 3.5mm connection, play the music directly from this source to the amplifier.
  • Check your settings.
  • Check the wiring connections on the output of your amp and the sub-woofer.
  • You may have a problem with the output circuit of your amplifier.
