Registering your Garmin device with the ActiveCaptain application
Registering your Garmin device has never been so easy. Follow the instructions below to register your Garmin device with the ActiveCaptain App:
1. Pair the ActiveCaptain App with your Garmin device. See related content for pairing instructions
2. Select My Registered Devices within the ActiveCaptain App
3. Verify your device is shown under Pending Registrations
4. A data connection will be required to register the Garmin Device. Disconnect from the Garmin device Wifi and either connect to a Wifi network which provides internet access, or use a cell data plan.
Note, if the Garmin device is not compatible with ActiveCaptain Pairing the Garmin device unit ID can be entered manually by pressing the + button on the My Registered Devices page.
