Reset the Xero A1, Xero A1i, or Xero A1i Pro to Factory Default Settings
Resetting the Xero® A1, Xero® A1i, or Xero® A1i Pro bow sight back to factory default settings will remove all profiles and calibration settings and return the bow sight back to its initial setup out of the box.
Reset Xero A1 or Xero A1i Sight
  1. From the Main Menu Select Drive app Android - settings gear
  2. Select Reset All Settings
  3. Select Yes
The sight will then reset back to factory defaults. The initial calibration can be started again.
Reset Xero A1i Pro Sight
  1. From the Main Menu Select Settings
  2. Select System Settings
  3. Select Reset All Settings
  4. Select Yes
