Venu 3 and 3S Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine estimated battery life specifications. Usage beyond what is listed below may result in reduced battery life. The information presented below is a reference-only guide for general use of the Venu® 3 and Venu® 3S smartwatches.
The following usage assumptions were used to determine the estimated battery life for the Venu 3 Series. Unless otherwise stated, all default software settings and configurations are assumed for battery life specifications.
Smartwatch Mode Usage Assumptions | |
Notifications per Day | 50 |
Number of Interactions per Day | 32 |
Device-Generated Alerts per Day (Move or Goal Alerts) | 10 |
Hours per Day Outside of Bluetooth Range of Phone | 1 |
Display Brightness & Timeout | Default Settings |
Watch Face¹ | Default |
Number of Gestures per Day | 750 |
Pulse Ox Mode | Disabled by Default |
Number of Minutes of Music Streaming | 0 |
Number of Timed Activities | 0 |
Venu 3 Smartwatch Mode Battery Life | Up to 14 days |
Venu 3S Smartwatch Mode Battery Life | Up to 10 days |
Smartwatch Mode Usage Assumptions – Display Always On | |
Average Number of Hours Spent Outside² | 5 |
Watch Face | Default |
Average Number of Hours per Day Sleep³ | 8 |
Display Timeout | Always On |
Venu 3 Smartwatch Mode Battery Life | Up to 5 days |
Venu 3S Smartwatch Mode Battery Life | Up to 5 days |
Activity Mode Usage Assumptions | |
Number of Interactions per Hour | 10 |
Minutes of Interaction Post-Activity | 1 |
Number of Gestures per Hour | 25 |
Assumed Temperature Range for Battery Life Specifications | 10C – 40C |
Venu 3 GPS-Only Mode without Music Battery Life | Up to 26 hours |
Venu 3 All Systems (Default) Mode without Music Battery Life | Up to 20 hours |
Venu 3 GPS-Only Mode with Music Battery Life | Up to 13 hours |
Venu 3 All Systems (Default) Mode with Music Battery Life | Up to 11 hours |
Venu 3S GPS-Only Mode without Music Battery Life | Up to 21 hours |
Venu 3S All Systems (Default) Mode without Music Battery Life | Up to 15 hours |
Venu 3S GPS-Only Mode with Music Battery Life | Up to 10 hours |
Venu 3S All Systems (Default) Mode with Music Battery Life | Up to 8 hours |
Battery Saver Feature
The Venu 3 and Venu 3S also supports a feature called Battery Manager. Enabling this feature changes the behavior of the watch and disables certain functionality (see table below for some examples) to help prolong battery life. The table below summarizes the estimated battery life when Battery Saver is enabled.
Smartwatch Mode Usage Assumptions with Battery Saver Feature Enabled | |
Phone Connection | Disabled |
Display Brightness & Timeout | Low/Short |
Watch Face¹ | Low Power Watch Face |
Number of Gestures per Day | Gesture Mode Disabled |
Pulse Ox Mode | Disabled |
WiFi Usage | Disabled |
Music Playback Through Bluetooth Headphones | Disabled |
Auto Activity Start | Disabled |
Wrist Heart Rate | Disabled |
Venu 3 Smartwatch Mode Battery Life | Up to 26 days |
Venu 3S Smartwatch Mode Battery Life | Up to 20 days |
1The “default” watch face is the watch face present on the device when it is taken out of the box. The Venu 3 Series products are designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
2This device utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
3The average number of hours per day of sleep is determined by the user-configured bed and wake times (a "sleep period"), not the number of hours the user actually sleeps. During this sleep period, the device's display is turned off. As a result, setting a shorter sleep period may decrease the battery life experienced in display always on mode.
