Syncing Amazon Music Content to a Venu Series Watch
For the process outlined below to work you will first need to make sure you have a Venu® Series watch eligible for on-board music downloads. This includes:
  • Venu®
  • Venu® 2 | Venu® 2S
  • Venu® 2 Plus
  • Venu® 3 | Venu® 3S
  • Venu® Sq - Music Edition | Venu® Sq 2 - Music Edition
What Are the Requirements to Use the Amazon Music Connect IQ App?
  • The watch must be paired to your smartphone through the Garmin Connect app.
  • The watch must be set up to connect to a Wi-Fi Network. For help see: Adding Wi-Fi Networks to Compatible Watches.
  • An Amazon Prime or Amazon Music Unlimited account is required. For help see: What is the Difference Between Prime Music and Amazon Music Unlimited?
  • You must be the Amazon Prime primary account holder. A family member sharing the benefit of Amazon Prime Music will not work.
  • If you have never used the GPS on your watch, or if the battery has been completely discharged recently, you may be prompted to enable GPS after accessing the Amazon Music app. GPS can be enabled by choosing an outdoor activity. For instructions see: Going for a run.
  • The app will work in the following countries:
    • Canada
    • France
    • Germany
    • India
    • Italy
    • Japan
    • Spain
    • United Kingdom
    • United States
I Meet the Requirements. What's Next?
The steps listed below need to be completed when first setting up the Amazon Music app with your Venu series or Venu Sq - Music Edition watch. Once complete, you will only need to follow the last step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Amazon Music Connect IQ App
  1. Select the following link to download the app: Amazon Music Connect IQ app.
  2. Select the Down arrow next to the word download within a blue box button.
  3. If prompted, sign in to your Garmin account.
  4. Select your device to download the app.
  5. Acknowledge any app permission requests.
  6. The message should indicate that the app will be installed during the next sync. If this does not occur automatically, below are options to sync your device:
    • To sync via Bluetooth: Be in range of your paired smartphone, then press and hold the top right button to access the Controls Menu. Select blue arrows circling each other to sync.
    • To sync via Wi-Fi: Be in range of your Wi-Fi network, then press and hold the top right button to access the Controls Menu. Select blue arrows circling each other to sync.
    • To sync using Garmin Express: Connect the device using supplied power/data cable to a computer. Open Garmin Express. A sync will automatically occur once the device is detected.
Once the sync is complete, the Amazon Music app will be installed on your device.
Step 2: Set Up the Amazon Music Connect IQ App on the Watch
Once the app is installed, you will be prompted on the watch to continue the setup process.
  1. Press and hold the bottom button.
  2. Select Gear Icon or Settings.
  3. Select Music.
  4. Select Music Providers.
  5. Select Amazon Music.
  6. The screen should prompt you to visit https://amazon.com/code on a mobile device or personal computer.
    • The code provided on the watch will tie it to your Amazon account.
Once completed allow up to a few minutes for the watch to proceed to the main menu.
Step 3: Select and Sync Content to the Watch
NOTE:  Your watch must be able to connect to your Wi-Fi network to download content from Amazon Music. For help see: Adding Wi-Fi Networks to Compatible Watches.
  3. Select Music.
  6. Select Browse.
  7. Select a category then choose the content you want to sync to your watch.
  8. The watch will attempt to connect to your Wi-Fi network.
    • We recommend plugging the watch into a charger near the Wi-Fi router for the best results.
After you have added content to your watch, any changes you make to your playlist(s) will sync over automatically when your watch is charging and in the range of a saved Wi-Fi network.
You can also manually initiate a sync to update playlists and report all songs played to Amazon Music by following these steps:
  3. Select Music.
  6. Select Sync.
  7. The watch will attempt to connect to your Wi-Fi network.
