Changing the Activity Class Setting in Garmin Connect
The activity class setting in Garmin Connect can be adjusted to influence the calorie burn on some older Garmin devices as well as body fat calculations on the first generation Index Smart Scale.  To change this setting in Garmin Connect, select your option below to reveal instructions.
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Settings.
  4. Select User Settings.
  5. Select Activity Class.
  6. Swipe up or down to select number 0 - 10.
  7. Select Done (Android) or Save (iOS)
Garmin Connect Web
  1. From a web browser go to connect.garmin.com
  2. Select circular Profile in upper right of screen.
  3. Select Account Settings.
  5. Select Activity Class number 0 - 10.
  6. Select Save.
To learn move about the activity class setting see:  What Is the Activity Class Measurement in Garmin Connect?
