Sending and Receiving Wirelessly With the GPSMAP 276Cx
Like many Garmin handhelds, the GPSMAP® 276Cx can send and receive data wirelessly to other Garmin models using ANT+ or Bluetooth technology. You can share waypoints, routes, and track wirelessly. Before you can share data wirelessly, you must be within 3 m (10 ft.) of a compatible device.
Sending Data
  1. Power on the GPSMAP 276Cx handheld
  2. Navigate to the Main Menu
  3. Navigate to either Route, Points, or Track
  4. Highlight the item you wish to send and press Menu
  5. Select Send Wirelessly
  6. The other compatible device must then be set to Receive
Receiving Data
  1. The other compatible device must be attempting to send data
  2. Power on the GPSMAP 276Cx handheld
  3. Navigate to the Main Menu
  4. Navigate to either Route, Points, or Track
  5. Press Menu
  6. Select Receive Wirelessly
