Setting up the BC 50 Series Wireless Backup Camera
The BC 50 Series wireless backup camera is a multi-purpose Wi-Fi-enabled camera intended to help drivers easily spot vehicles, pedestrians, and other hard-to-see obstructions behind their vehicle. This camera uses Wi-Fi to connect the compatible GPS.
See the detailed video below for more info on setting up the BC 50 Wireless Backup Camera.
See BC 50 Installation Instructions here.
See BC 50 with Night Vision Installation Instructions here.
- Garmin recommends having the BC 50 professionally installed.
- Depending on the wiring options chosen, when the paired GPS is powered on
- It can automatically display camera footage every time the vehicle is shifted into reverse, if the camera is wired to your reverse lights for power.
- It can allow toggling between the navigation display and backup display modes at the press of a button, if the camera is wired to constant power.
- Only the BC 50 with night vision is equipped with NightGlo technology, which illuminates up to 20' (6 meters) behind your vehicle for exceptional visibility at night.
- Camera automatically switches between day mode and night mode based on light levels.
- An optional 50' (15 meters) extension cable (sold separately) is available that will add to the transmission range to provide a range up to 100' (30 meters) for extended vehicles and vehicle-trailer configurations.
See Pairing the BC 50 Series Wireless Backup Camera for pairing instructions.
