How to Activate a New Navionics+ Updates Card
Navionics+ Updates is a blank card that is activated with an outdated or expired card, or certain cards from other manufacturers, through our Chart Installer program. Once the card is activated, additional steps are required to download charts to the card for use in your plotter.
For a complete list of eligible activation cards, click here.
Activation
Once you have successfully downloaded the Chart Installer, plug your new Navionics+ Updates card into your computer and follow the prompts on the screen.
  1. Remove your new Navionics+ Updates card from your computer.
  2. Plug in your outdated or expired card or a eligible card from another manufacturer.
  3. Remove the card inserted in step 2.
  4. Plug your new Navionics+ Updates card back into your computer.
You will receive a message that your Navionics+ Updates card is now active.
TIP:  If the activation steps are not proceeding and you are using USB card reader1, try removing the entire card reader from the USB port between steps.
Region Selection and Download
Choose from one of our Large coverage areas to associate with the card. Once you have confirmed your choice, you will be prompted to select and download chart data to your card.
  • For Navionics+ Updates on MSD/SD (part number 010-13222-00), select from the available chart layers on the left-side of the screen to download those layers for the entire coverage area.
  • For Navionics+ Updates Downloadable on CF (part number 010-13223-00), use the selection box on the map to select the area you want to download from within your coverage. Then choose the chart layers on the left-side of the screen to download those layers for the selected area.
Additional Notes
Your original card can no longer activate another Navionics+ Updates card. Navionics chart cards used for activation will also no longer be able to receive updates.
IMPORTANT:  Do not discard your original plotter card!
  • Any saved SonarChart Live files on your card can be moved to your new card when you receive it. Here's how.
  • Your card is still functional in your plotter - just without the benefit of chart updates or advanced features.
1 Navionics does not provide a USB card reader with the purchase of a new card.
Related
