Can I Move an inReach Device from One Account to Another Account
Adding an inReach Device to an Existing Personal Account does not allow Personal Plan subscribers to have multiple active inReach devices assigned to that user. Only one activate inReach device can be assigned to the account user at a time. If you need to have multiple inReach devices active, you will want to create a separate account for each inReach device.
Options for teams, businesses, or professional organizations: A Professional inReach subscription is required. Switching to a Professional account will make managing multiple users and devices easier and open the door to communication and tracking features that improve your inReach experience. See  Switching My inReach Subscription From a Personal Account to Professional Account for information on moving to a Professional Account.
 If you already added another inReach device to your account you will want to follow the steps below depending on if you activated the inReach device.
My inReach Device Hs Not Been or is Currently Not Activated
  1. Log into your account at explore.garmin.com.
  2. Select the Plans & Devices tab.
  3. Select Manage Device next to the inReach you wish to remove.
  4. Select Remove.
  5. Select log in log out explore website.
  6. Select Log Out.
  7. Follow the steps in How to Activate a New inReach.
My inReach Device is currently Active
IMPORTANT: Any communication feature with the iridium network, including triggering an SOS, will not function after cancelling the service. Make sure no one is using the inReach until you have reactivated the inReach on the new account.
  2. Select Plans & Devices tab.
  3. Select Edit under Subscriptions.
  4. Select Cancel Service.
  5. Select Cancel Service in the pop up window.
    • The cancellation make take a few minutes and the Subscription status may not reflect the change immediate. After a few minutes, refresh the webpage.
    • Annual Subscriptions: A box may appear if there is any early termination fees.
  6. Once the inReach device lists Deactivated under Subscription, select Manage Device.
  7. Select Remove.
  8. Select log in log out explore website.
  9. Select Log Out.
  10. Follow the steps in How to Activate a New inReach.
