Using the Trip Planner on an Acura NSX Navigation System
Your Acura NSX navigation system has the ability to create customized trips with up to 30 locations in a single trip and will allow you to edit them. This can be done using the Trip Planner feature built into the system.
Creating a Trip:
1. Touch Navigation
2. Touch Apps
3. Touch Trip Planner
4. Touch New Trip
5. Touch Select Start Location
6. Search for the start location
7. Touch Select after touching the start location
8. Touch + (in the upper left corner)
9. Search for the end location
10. Touch Select after touching the end location
11. Touch + (in the upper left corner)
12. Search for the next destination in the trip
13. Touch Select after touching the next destination
14. Repeat steps 11 through 13 to continue adding destinations
- Use the arrows on the right side of the screen to drag the destinations into the desired order
15. Touch Next after selecting all destinations
16. Enter a name for the trip
17. Touch Done
18. Touch Go to begin the trip or Back to return to the Trip Planner menu
Editing a Trip
1. Touch Navigation
2. Touch Apps
4. Touch the trip you wish to edit
5. Touch the menu bars (3 lines) in the upper left corner
The options for editing the trip will now appear on the screen.
From the Edit Menu you Can:
Edit Destinations: This option allows the order of the destinations to be changed, destinations to be added, and destinations to be deleted.
Delete Trip: This option will permanently delete the selected trip from the system. After selecting this option, a final prompt confirming the deletion will appear.
Rename Trip: This option allows the trip name to be edited from the original name entered.
Optimize Trip: This option will optimize the trip into the most efficient order based on your navigation settings. For the optimize feature to work, the trip must have at least 4 destinations.
