Creating, Editing, or Deleting a Trip on a zūmo 395 or zūmo 595 Using Trip Planner
Creating a multiple-point trip allows navigation among several points. Trips can be saved to the device's internal storage for use at a later date by using Trip Planner. The device will save up to 100 trips.
Create a Trip
1. Touch Apps
PND zumo 595 - Trip Planner - select apps
2. Touch Trip Planner
 PND zumo 595 - Trip Planner - select TP
3. Touch the PND settings wrench v2 wrench icon
PND DA 50 - Trip Planner - create new
4. Touch Create Trip
PND zumo 595 - Trip Planner - create trip
5. Touch Select Start Location
Note: The Start Location is the first stop on the route.
PND DA 50 - Trip Planner - select start 1
6. Locate the starting point using the search options
PND zumo 595 - Trip Planner - search for locations
7. Touch Select
PND zumo 595 - Trip Planner - select location
8. Touch Add Location to add a second point
PND zumo 595 - Trip Planner - add location
9. Follow steps 6 through 8 to locate and add up to 30 total points. Touch a point to show additional options
PND zumo 595 - Trip Planner - location options
Additional Options
  • Touch the PND - Trip Planner - add stop icon add icon to add a stop between locations.
  • Touch the PND settings wrench v2 wrench icon to change a location.
  • Touch RV 785 - Trip Planner move icon to change the order of points.
    • Touch and hold the PND - drag icon transparent move icon next to a point and drag it to a location on the list.
PND zumo 595 - Trip Planner - change order
  • Touch the PND - Trip Planner waypoint icon orange flag icon to convert a waypoint into a shaping point.
    • This builds a route passing through that point without navigating to it.
    • The icon will change to a  PND - Trip Planner shaping point blue shaping point icon and the route will recalculate.
PND zumo 595 - Trip Planner - shaping point
  • Touch the VIRB trash transparent cropped delete icon to remove a point.
    • Then touch Yes.
PND DA 50 - Trip Planner - delete point
10. Touch Select Destination and follow steps 6 and 7 to select a final destination
PND zumo 595 - Trip Planner - select destination
11. Touch Next. The route will now calculate
 PND zumo 595 - Trip Planner - calculate route
12. Touch Save
PND zumo 595 - Trip Planner - save route
13. Type the desired name for the route and touch Done
The trip will now be saved to your device.
Edit a Trip
1. Touch Apps
3. Touch the name of the trip
PND zumo 595 - Trip Planner - select trip
4. To edit the locations, touch a location, and choose an option. Click on Editing Options below to see the options available.
Editing Options
    • Then touch Yes.
5. Touch the PND settings wrench v2 wrench icon for more editing options
PND zumo 595 - Trip Planner - edit trip options
Select from the following options:
  • Share: Transfer the trip to another zūmo device.
    • Routes can be shared over Bluetooth or saved to an SD card.
  • Route Preference: Sets the preferred way to route the trip.
  • Shape Route
  • Optimize Order: Calculate the most efficient order to travel to all the points.
    • The start and end points will not be changed.
    • The route must have at least four points total.
  • View Turns: Lists turn-by-turn written directions.
  • Delete Trip: Removes the trip from Trip Planner.
  • Rename Trip: Changes the name of the trip.
  • Edit Schedule: Changes the departure and arrival times.
The trip will now be changed. When the trip has been edited to your satisfaction, touch Go! to proceed with navigation.
Delete a Trip
1. Touch Apps
3. Touch thePND settings wrench v2 wrench icon
PND DA 50 - Trip Planner - edit trip
4. Touch Delete Trips
PND zumo 595 - Trip Planner - delete trips
5. Touch the trip(s) to delete to place a  PND check iconcheckmark next to them, then touch Delete
 PND DA 50 - Trip Planner - select trips to delete
6. Touch Yes
PND DA 50 - Trip Planner - confirm delete trip
The trip(s) will now be deleted.
To Navigate a Trip Using Trip Planner
1. Touch Apps
3. Select the Trip
4. Touch Go!
5. Select the Next Destination of the Route
  • Select the Green Flag to route from your current location to the beginning of the route, and then the full trip.
  • Select the Orange Flag to skip the starting location and route from your current location to the waypoint selected in the route, and then the remaining trip destinations in order.
  • Select the Checkered Flag to route from your current location skipping all the points in the route and taking you the quickest way to the destination point.
6. Touch OK
7. Touch Start
Related
