Using Newer GPSMAP, Montana, Foretrex, and eTrex Series Devices With BaseCamp on a Mac
The following outdoor handheld devices may not be recognized by the BaseCamp™ program on Mac:
eTrex® SE
eTrex® Solar
Foretrex® 801
Foretrex® 901
GPSMAP® 67
GPSMAP® 67i
Montana® 710
Montana® 710i
Montana® 760i
If you wish to use BaseCamp with one of these devices, a Windows computer should be used. If you do not have access to a Windows computer, these devices can be used with the Garmin Explore™ app on an Android or iOS mobile device1 to transfer data to or from the device. You can then import or export the files you wish to work with in BaseCamp.
Moving Data From the Handheld to BaseCamp (Mac)
1. Pairing, Syncing, and Exporting Files With the Garmin Explore App
Use the steps in the following FAQs to connect and sync your handheld device with the Garmin Explore app, then export the files you need.
