Troubleshoot Broadcast Mode on the Tread and PRO 550 Plus
The PRO 550 Plus has the ability to transmit dog tracking information to the Tread® GPS navigator.
The receiving device can only pick up dog tracking information from a single device but you can transmit to multiple receiving devices at one time. For example, the PRO 550 Plus can transmit to multiple Tread navigators or other compatible devices at the same time.
Follow the Troubleshooting Steps Below if you are Having Trouble with the any of the Broadcast Mode Compatible Devices:
- Ensure all devices are on latest software version.
- Transmitting device and receiving device must be within 15 feet of each other (closer is recommended for testing and troubleshooting).
- Ensure you are actively tracking a compatible dog collar with the handheld.
- Ensure only the two devices that should be communicating are on (power off all other transmitting handhelds or disable their Broadcast mode).
- The Pro 550 Plus always has the Broadcast Mode enabled.
5. Check the settings on the Tread device:
- Go to Main Menu
- Select the Dog Icon or:
- Select Apps
- Select Dog Tracking
- Check all dog settings for accuracy
- Select Settings (Wrench icon)
- Power the Tread navigator off, then back on
- Press and Hold the Power Key for 6 seconds, then Tap "Power off" on the screen
- Check to see if they have reconnected.
- If not, move on to Unpairing and Rebooting steps below
6. Unpair the Tread navigator
- Go to Main Menu
- Select Wrench for Settings
- Select Unpair
- Confirm the selection
- Power OFF the Tread device
- Hold the Power Key until a prompt appears on the screen, and select Off.
- Power the Tread® back on
- The handheld and Tread navigator should now be reconnected
If other compatible receiving devices are available, try transmitting to them to see if they will pick up the signal
