Navionics Boating: GPS Coordinate Format
The Navionics® Boating app will display coordinates in degrees and decimal minutes (dd° mm.mmm'). All Navionics charts are built using a datum reference of WGS 84.
There are 3 different coordinate formats:
- Decimal Degrees (dd.dddd°)
- Degrees and Decimal Minutes (dd° mm.mmm')
- Degrees, Minutes and Seconds (dd° mm' sss")
There is not a way to convert coordinates or to display another format, within the app itself. To convert the coordinates found in the Navionics app to another format, a GPS coordinate converter can be found at http://www.csgnetwork.com/gpscoordconv.html.
