Garmin Catalyst Error Messages and Definitions
When using your Garmin Catalyst, an error message may display while in operation. Below is a list of possible error messages and their definitions.
Failed to Map Track Shape. Make Sure you Consistently Drive the Same Configuration.
Unable to build a map of the track because of poor GPS reception or the vehicle didn’t drive the same path each time, and video recording never started.
Failed to Map Track Shape. Make Sure you Consistently Drive the Same Configuration. Save Session Video Anyway?
Unable to build a map of the track because of poor GPS reception or the vehicle didn’t drive the same path each time, but the video recording started.
Incomplete Session Data or Failed to Map Track Shape or No Laps Detected
Video recording started, but ended and was not saved due to going off the track or being in a wreck.
No Laps Detected: Be sure to Select the Correct Track and Drive At Least one Lap to Generate Session Results
The vehicle never crossed the start line, and the video recording never started.
No Laps Detected: Be Sure to Select the Correct Track and Drive At Least one Lap to Generate Session Results. Save Session Video Anyway?
The vehicle never crossed start line, but video recording started.
Recover Session: Selected Track Configuration did not Match What you Drove. Make Sure you Select the Configuration that Matches What you Drove.
The vehicle crossed the start line, but the path driven didn’t match the track selected. You will be prompted to select the correct track.
Note: This can happen if the original track map recorded was from a session with poor GPS reception or if you have driven this configuration with an incorrect path previously. The map can be cleared in the Tracks page by selecting the track, then tapping the track name 10 times to be prompted whether you want to reset the track configuration in the next session.
See: Clearing the Track Shape on the Garmin Catalyst
Recover Session: Selected Track Configuration did not Match What you Drove. Try Selecting a Different Track.
The vehicle never crossed the selected track’s start line, but the Catalyst was able to detect a drive in a circuit, and it recorded a track with an artificial start line. The Catalyst will prompt to select the correct track or make a custom track.
Note: This can happen if the Catalyst had poor GPS reception, and it never saw the vehicle cross the selected start line.
Unknown Error: An Unknown Error Occurred.
The error is unknown, and the video recording never started.
Unknown Error: An Unknown Error Occurred. Save Session Video Anyway?
The error is unknown, but video recording started.
