Using the Alpha 200 Plus or Alpha 300 Series with Garmin BaseCamp on a Mac with OS 11 and Newer
The Alpha® 200 Plus, Alpha 300, and Alpha 300i dog tracking handhelds will not be recognized by Garmin BaseCamp™ on Mac OS 11 or newer. If you wish to use BaseCamp with one of these devices, a Windows computer should be used. If you do not have access to a Windows computer, these devices can be used with the Garmin Alpha app on an Android or iOS mobile device1 to transfer data to or from the device. You can then import or export the files you wish to work with in BaseCamp.
Moving Data From the Handheld to BaseCamp (Mac)
1. Pairing, Syncing, and Exporting Files With the Garmin Alpha App
Use the steps in the following FAQs to connect and sync your handheld device with the Garmin Alpha app, then export the files you need.
