Improving the GPS Accuracy, Distance, and Speed Readings of a fēnix 7 or fēnix 7 Pro Watch
With a strong satellite signal, the GPS position reported by an outdoor watch should be accurate to 3 meters or 10 feet. A weaker satellite signal may decrease position accuracy, affecting the accuracy of the distance and speed readings. The articles linked below provide information about a number of factors that can affect the accuracy of position, distance and speed readings, and steps that can be taken to prevent or minimize factors that decrease accuracy.
GPS Drift and Environmental Factors
GPS Drift and Environmental Impacts on GPS Accuracy for the fēnix 7 and fēnix 7 Pro Watches
This article covers factors that degrade GPS signal, along with how GPS Drift can add additional distance to your activities. Incorrect speed readings are often related to incorrect distance readings. If you are having issues with speed and distance, this is a good place to start.
Change Settings to Improve Accuracy
Settings that Improve the Distance and Speed Accuracy of the fēnix 7 and fēnix 7 Pro Watches
This article walks you through making changes to your outdoor watch settings that can improve the accuracy of speed and distance.
Using a Dual GPS Frequency Garmin Watch
The fēnix® 7 Sapphire Solar Edition watches and fēnix® 7 Pro watches all feature "Multi-Band" or Dual-frequency GNSS (Global Navigation Satellite System) capability, which can help to improve speed and distance accuracy when environmental factors like tall buildings or trees are difficult to avoid.
Satellite Prediction Data
Downloading GPS Satellite Location Data to a Garmin Fitness Device
Satellite prediction data helps your watch predict where satellites are to get a GPS signal more quickly. Expired data can cause your watch to take much longer to acquire GPS. If you are having trouble getting a GPS signal in areas with a clear view of the sky, use the information in this article.
NOTE: For activity tracking and step distance accuracy, see - Improving the Step Distance Accuracy of My Garmin Outdoor Watch.
