Xero Locations Compatible Devices
The Xero Locations feature is only available on the Xero® A1i Bow Sight, Xero® A1i PRO Bow Sight, and Xero® X1i Crossbow Scope. This feature enables the use of a compatible GPS device to know where the target was located when the shot or range was taken. The waypoint of your shot or range is sent to the compatible device via an ANT+ broadcast. This will help give you an idea of where your arrow, bolt, or target should be to help start your search.
Compatible Devices with Xero Locations Laser Locate Feature
A list of Garmin handheld and wearable products compatible with Xero Locations can be seen on the Compatible Devices tab of the product page. Use the links below to view compatible devices.
