Features of the Tacx Blue Twist Basic Trainer
Below are details regarding the features of the Tacx Blue Twist trainer that will have influence on your indoor cycling experience.
Flywheel
The Blue Twist is equipped with a 1.2kg (2.65 lbs.) flywheel. The weight of the flywheel in combination with the rotational speed creates a large inertia. This inertia ensures the smoothness of cycling you would expect.
Resistance Level
Blue Twist is controlled by a lever on the resistance unit, so you set the required resistance at forehand.   Blue Twist can simulate up to 700 watts power using the lever.
blue twist
App Compatibility
Using Garmin's Bluetooth Speed and Cadence sensors will allow you to experience virtual power in many different cycling apps such as the Tacx Training app.
