Viewing Multiple Garmin Video Sources and Axis Video Support
The CVBS IN port can connect to one composite video source. To display multiple cameras requires additional equipment.
The key to accomplishing this is video equipment that utilizes Internet Protocol (IP). The Axis Video Encoder has coaxial connections for composite video. It serves to convert analog video into digital video and transfer it across the network via a single Ethernet cable. This setup allows users to view up to four analog video screens on a single combination page.
Compatible Axis devices
  • Axis F44 (dual audio input)
  • Q7424-R Encoder
  • Q7424-R MK II Encoder
  • P3905-R (camera)
  • M3024 (camera)
Compatible chartplotters
  • GPSMAP™  7x2 chartplotter | GPSMAP™  7x3 chartplotter | GPSMAP™  9x2 chartplotter |GPSMAP™  9x3 chartplotter
  • GPSMAP™ 10x2 chartplotter | GPSMAP™  12x2 chartplotter | GPSMAP™ 12x3 chartplotter | GPSMAP™ 16x3 chartplotter
  • GPSMAP™ 74xx chartplotter | GPSMAP™ 76xx chartplotter
  • GPSMAP™ 8xxx chartplotter
Our integration makes it possible to view video on every screen on the  boat and view multiple streams on the same screen, if desired. Control the camera's pinch-to-zoom and pan / tilt settings with gestures directly on the chartplotter screen.
Use of an Axis encoder allows the user to convert analog camera signals, such as those used by the  GC™ 10, to video over IP (internet protocol).
For additional information, see the Camera Integration Guide
