Minimum and Maximum Password Lengths for Wi-Fi Networks
When connecting to a Wireless Network on your automotive device, if the network is password protected it must be at least 8 characters in length. The maximum length is listed below and depends on the type of network.
If your network password is less than 8 characters, the easiest workaround is to change your network password to meet this minimum requirement.
The Wi-Fi network connection on your automotive device would have to be set up manually if you wish to retain a password under this limit.
To Manually Connect to a Wi-Fi Network
- Open the device's Settings menu
or
- Touch Wi-Fi
- Touch the Menu button
- Three vertical dots in the top right corner
- Touch Add network
- NOTE: Hidden networks are not compatible with Wi-Fi updates on some Garmin devices.
- Enter the SSID for your network
- Check the documentation for your router if you are unsure how to find this
- Maximum length is 32 characters
- Scroll down and touch Security
- Select the security type your network is using
- Check your router's network security settings if you are unsure of what setting to choose
- WEP - Maximum key length is 16 characters
- WPA-PSK/WPA2-PSK - Maximum key length is 63 characters
- Scroll down and touch Password
- Enter the password for your network and touch Save
The device will now be connected to your home Wi-Fi network.
See Wireless Map and Software Update Instructions for more info.
- See Wireless Track and Software Update Instructions for the Garmin Catalyst
