Customizing Data Fields on the Map, Compass and Trip Info Pages with the inReach SE+/Explorer+
Data fields allow you to customize the items you see on the screen when using the map, compass or trip information on an inReach SE®+ or inReach Explorer®+ handheld. The steps below will help with making changes to the data fields.
- Select either the Map, Compass or Trip Info
- Press
on the inReach handheld
- Select Change Data Fields
NOTE: Small Text will allow 6 data fields, Large Text will allow 3. - Use the directional keypad to select a data field to modify
Note: Trip Distance is the distance of the current track being recorded; Odometer is the total distance accumulated on the inReach handheld. - Select the type of data field you wish to display
Note: Sunset and Sunrise data fields will need a current basic forecast request to display data within that field.
