Data Loaded to an SD Card an Automotive Device will Recognize
Garmin Automotive Devices Will Read a Variety of Data from an SD card. The Recognized Data Types are Listed Below:
  • Garmin map image files loaded to the card from Garmin Express or through Garmin's downloadable web content
  • User-created routes for devices supporting multiple-point routing1,2
    • These files do not require you to keep the memory card installed in the device once imported
    • Files will be imported to the internal memory
  • Waypoints1 and custom Points of Interest (POI) files
  • MP3 Files
Some devices require you to import routes and waypoints before they will appear on the device.
GPX files must be located in a "GPX" folder within a "Garmin" folder on the SD card. You can create these folders manually when the SD card is connected to your computer.
See  for more information.
