Recording and Saving Tracks on a GPSMAP 276Cx
By default, the GPSMAP® 276Cx navigator records a track log automatically while it is on and receiving a GPS signal. You can pause and start track recording manually, and save the active track when needed.
Recording a Track
Begin moving to record a track.
Press MENU twice to access the main menu.
Select Track > Active.
Select an option:
To pause track recording, select Stop.
To start track recording, select Start.
Saving the Active Track
Select Track.
Select an option:
Select Save to save the entire track.
Press MENU, then select Save Portion to save a portion of the track. A list of track segments will then be presented.
Select the first track segment to save, then select the last track segment to save.
