My Rear Wheel Is Not Centered on My Trainer
If the rear wheel of your bike is not centered on the middle of the roller, you have the ability to adjust the bike following the steps below.
Viewing the trainer from the rear or top, use the right adjustment bolt (circled below) to center the wheel by turning it in or out.
You will need to loosen the blue security nut in order to make this adjustment. Make sure that you tighten down the nut once the rear wheel is centered.
