Important Notice: Beware of Fake Garmin Ads!
Garmin Malaysia has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Editing Check-In Contacts in the Garmin Messenger App
Check-in messages are a convenient way to send messages to specific group of friends and family. There are three check-in messages to choose from:
  • Check Mark I'm checking in, everything is okay.
  • Triangle I'm starting my trip.
  • Square I'm ending my trip.
You can customize the recipient list of your check-in messages, but you cannot customize what the check-in messages say. Check-in messages will include your location if available.
Editing Your Check-in Contacts
NOTE: To edit your check-in contacts, your phone must have Wi-Fi or mobile data available so the changes can be saved to your online account. It is best to edit check-in contacts before leaving on a trip. If your inReach® account was created prior to September 27th, 2022, you may instead see Presets with an option to Set Up Check-in (see Differences Between Preset, Check-in, and Quick Text Messages for more details).
  1. Ensure your compatible inReach device is powered on and paired with the Garmin Messenger™ app.
  2. In the Garmin Messenger app, select Device.
  3. Select Check-In.
  4. Select Edit Check-in Contacts to customize the recipient list of your check-in messages:
  5. Select an option:
    • Touch the field next to To: to manually enter SMS numbers, email addresses, or inReach addresses. You can also start typing the name of a saved contact, then select the contact from the list of results.
      -OR-
    • Select Plus Symbol, then select System Contacts, inReach Contacts, or MapShare™ to add contacts that are already saved to your phone or inReach account.
      NOTE: Selecting MapShare as a contact allows the message to appear on your MapShare page. This option only appears if you have enabled the MapShare feature.
  6. Select SAVE.
Related
