Adjusting the Vented Titanium Bracelet for the quatix 6
Garmin recommends taking the quatix 6 watch to a jeweler if the vented titanium bracelet (metal band) needs to be adjusted for size.
The three links closest to the QuickFit mechanism (on each side of the band) and the QuickFit mechanism, are shaped differently than the other links in the band. It is recommended to not remove these links to shorten the band. In the image below, the links that should not be removed are identified with a red X.
Red x's on links that cannot be removed from a quatix 6 metal band
