How to use Easy Route Shaping on a Created Route
A calculated route can be manually shaped to change its course. Adding a shaping point will allow you to customize the calculated route to take a certain road or go through a certain area without adding a via point or destination to the route.
To Manually Shape the Route:
1. Select a location on the map when in an active route
2. Touch Shape Route
- Allow the route time to calculate
3. Touch the map again to add another location
4. When you have finished shaping the route, touch Go!
This will shape the route to the way you want it to go. You can add up to 30 shaping points to your route.
You can Also Save the Changes to Your Route for Future use by Going Into Trip Planner:
1. Press the Back arrow to return to the Where to? and View Map screen
2. Touch Apps
3. Touch Trip Planner
- You have may need to touch Navigation or dezl first
4. Touch Saved Trips
5. Touch My Active Route
6. Touch Save
7. Type the desired name for the route, then touch Done
The custom route will now be saved as a trip in Trip Planner.
