WIN_SMARTTTEMPFILE.CPP error in a Garmin application
Description
The WIN_SMARTTTEMPFILE.CPP error can occur if a Garmin application is having issues accessing the Windows' temp folder.
Resolution
Clean out the temp folder. To clean the temp folder:
- Press Windows key + R
- Type %Temp%
- Click OK
- Delete all or as many files as possible from this folder
- Close the Temp Window
- Re-run the Garmin application after cleaning out the temp folder
Once the temp folder has been cleaned out, the error message should no longer display.
