Changing the Language on the Alpha 100
If your Alpha® 100 has been set to another language, you can change the language with the steps below.
  1. From the Main Menu, select Setup (the blue wrench icon)
    Alpha100 Homescreen Setup Wrench
  2. Select System (Yellow icon of handheld gps at the top of the list)
    alpha100 setup system icon graphic
  3. Select Text Language (the third menu field in the list)
     Alpha 100 text language graphic
  4. Select the desired language
    NOTE: English will always at the top of the list of other possible languages loaded in the system
    alpha 100 english graphic
Once the desired language is selected, you can return to main menu, or any other tool in the system to verify the language has changed.
