(2020) Service Bulletin 2091 Rev A: G1000 NXi System Software Version 3643.03 For Embraer EMB-500 Phenom 100 and EMB-505 Phenom 300 Aircraft
PRODUCTS AFFECTED:
G1000 NXi-equipped Embraer EMB-500 Phenom 100 aircraft with system software version 3643.00 or 3643.01 installed under STC SA01933WI are affected.
G1000 NXi-equipped Embraer EMB-505 Phenom 300 aircraft with system software version 3643.01 installed under STC SA01933WI are also affected.
CERTIFICATION AUTHORIZATION:
STC SA01933WI
COMPLIANCE:
MANDATORY: Compliance with the STC service bulletin is mandatory at the next 100-hour/annual inspection, not to exceed 6 months.
PURPOSE:
This Service Bulletin announces the approval of G1000 NXi System Software Version 3643.03 in Embraer EMB-500 Phenom 100 and EMB-505 Phenom 300 aircraft.
G1000 NXi System Software Version 3643.03 provides the following enhancements:
  • Phenom 100
    • Corrects the EDM (Emergency Descent Mode) annunciation color from red to green
    • Enables the CVR (Cockpit Voice Recorder) erase function
    • Enables the CVR failure indication
    • Enables the FDR (Flight Data Recorder) failure indication
    • Enables the cabin altitude high driven automatic thrust reserve inhibit
  • Phenom 300
    • Corrects issue with the VENTRAL RUD FAIL advisory CAS message displaying after engine start
    • Enables the FDR 1 (Flight Data Recorder) failure indication
    • Enables the FDR 2 (Flight Data Recorder) failure indication
