User Data Limitations of the Rino 750 Series
When sending or creating files for a Rino® 750 series handheld, keep in mind the following limitations:
2,000 GPX files
10,000 waypoints
No limit on geocaches (outside of max number of GPX files supported and memory available)
250 routes, 250 points per route; 50 points turn-by-turn routing
200 saved tracks
2,000 archive tracks
20,000 points per track
100 custom map tiles
50 contacts with 2,000 track points each
250 BirdsEye Imagery files
Mapping segments 15,0001
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 See Related for more information on map segments.
