Outdoor Handheld microSD or SD Card Not Detected, Recognized, or Incompatible in Garmin Express Software
If there is a problem with a microSD/SD card or the computer's USB configuration, Garmin Express™ software may fail to detect the card or display that it is incompatible.
NOTE: You may need to restart your computer to install any computer updates before performing the steps below.
  • Make sure the USB cable is plugged directly into the handheld and the computer:
    • Do not use a USB hub or extension cable.
    • Use the USB ports on the back of desktop computers.
  • Unplug all USB devices (except for the mouse and keyboard), reboot the computer, and connect again.
  • Try a different USB port on the computer.
  • Format the memory card. For instructions, see - Formatting a microSD/SD Memory Card for Outdoor Handhelds.
  • Try using a different microSD/SD card.
  • Run Garmin Express on a different computer
    • If using a Mac computer, you can try a different Admin User before trying another computer. Contact Apple for instructions.
A functioning microSD/SD card should be detected if these troubleshooting steps are taken.
Related
