- Select the App Drawer.
- Select Contacts.
- Select the Emergency-Hazard Triangle.
- Select Yes.
- All of your contacts receive the emergency alert, they can click Accept to initiate navigation to your location.
- Your Alpha displays a message indicating that your contact has started navigating to your location when the contact accepts your Emergency Alert Request.
Initiating and Navigating to an Emergency Alert
With an Alpha® dog tracking handheld, you can send an emergency alert via VHF MURS radio transmission to a Contact in your Tracked Devices list when you need immediate assistance and if you are away from your group/contacts.
This feature is separate from and unrelated to the dedicated SOS feature that uses inReach® technology on the Alpha 200i. It also requires that manual pairing of the handhelds be done before you get out in the field. Adding/Pairing with your Contacts has to be done during setup to ensure contact tracking is turned on (Active). See Related Contact for more information about Adding Contacts.
Initiating an Emergency Alert
Deleting an Emergency Alert Location
Once the emergency has been handled, you can delete the saved location in the Waypoint Manager.
