"You can only install apps from the Windows Store" Message When Installing Garmin Express on Windows 10 and Newer
The message You can only install apps from the Windows Store or The app you're trying to install isn't a Microsoft verified app when installing the Garmin Express™ software on a Windows 10 and higher computer means that your computer is set to only allow installation of programs from the Windows store. Since Garmin Express is obtained from the website Garmin.com rather than the Windows Store, your computer is blocking the installation of Express from continuing.
NOTE: If the following does not resolve the issue, or if you receive an error message referencing S Mode or This mode of Windows only runs verified apps from the Store, see the FAQ  Windows 10 S Mode and Garmin Applications.
To Change Your Computer's App Settings On Windows 10:
1. On your computer, click the Start menu
2. Select Settings
3. Select Apps
4. Select Apps and Features
5. Under the first heading, "Choose where to get apps" or "Installing Apps", click the drop-down box
choose where to get apps3
6. Select Anywhere or Allow apps from anywhere
    • If "Anywhere" or "Allow apps from anywhere" is not listed, select "Turn off App Recommendations, Show me app recommendations", or "Warn before installing apps from outside the Store."
Your computer will now be set to allow the installation of programs from any source. After Garmin Express is installed, you may return to this menu and change back to your preferred setting, if desired.
To Change Your Computer's App Settings On Windows 11:
2. Select Settings
Select Settings win11
3. Select Apps
Select apps win11
4. Select Advanced App Settings
 Select advanced app settings win11
5. Select Anywhere or another preferred option beginning with Anywhere in the dropdown options
Choose where to get apps win11
Your computer will now be set to allow the installation of programs from any source. After Garmin Express is installed, you may return to this menu and change back to your preferred setting, if desired. For more information on changing your app recommendation settings in Windows, please reference Change your app recommendation settings in Windows from Microsoft Support.
Related
