Navionics Boating: How to Convert a Track Into a Route
Select any of your saved tracks and convert them to a route using the Garmin ActiveCaptain® app1 and the same credentials as your Navionics® Boating app.
Exporting Your Data From the Boating App
You will need:
- A current subscription to the Navionics Boating app.
- The Garmin ActiveCaptain app from the app store. Get it on the Apple App Store or Google Play Store.
Login with the same Navionics/Garmin Account.
- Launch the Navionics Boating app.
- Choose the track to convert.
- Select Share > Export GPX File.
- Select ActiveCaptain from the list of apps available.
- The ActiveCaptain app will open automatically.
Select Import to import the selected track(s).
Converting Your Track Within the ActiveCaptain App
- At the top right of the screen, select Menu.
- Select User Data.
- Select the track from the list and tap it to display the details.
- Select Save as Route.
- Edit the route using ActiveCaptain.
- Select Back arrow at top left.
- At the User Data Screen; select Routes, tap on the 3 dots.
- Select Export to GPX File, then Confirm selection.
- Select Navionics Boating from list to export it directly into the Boating app.
1 An active chart subscription within ActiveCaptain is not required to complete this process.
