Searching Near a Different Location
Your device searches near your current location by default.  If your device cannot find the destination you have entered, it may be searching in the wrong area.
To Search Near a Different Location:
1. Touch Where To?
2. Touch the  search area at the top
3. Touch the preferred option in the list (scroll up or down to see all options)
Available Options:
Where I Am NowSearches near your current location (this is the default setting)
A Different CitySearches near a specific city you enter
Recent DestinationSearches near a recently found location listed in the device's Recent menu
Saved PlaceSearches near a location from the device's Saved menu
My Active Route1Searches along your currently active route
My Destination1Searches along the currently active route, but starts near the destination and works backward along the route
Upcoming Exits(Available on some devices) Searches near upcoming exits when driving on a controlled-access highway while not on an active route
To begin searching near your current location once again, return to the main menu to restore the default setting.
1These options are only available when you have entered a destination and your device is currently navigating an active route.
Try the Following Steps in Order if the Errors "No Matches Found" or "Cannot Find Search Results" Continue to Appear When Searching for a Destination:
