Creating Waypoints in the Earthmate App
The Earthmate® app can be used to create waypoints for use in the app, at explore.garmin.com, or on a compatible inReach® device. Waypoints created in the Earthmate app are automatically synced to a compatible inReach device when paired. Additionally, waypoints will sync from the Earthmate app to your inReach account when the app has an internet connection, and is synced. Use the instructions below to create waypoints in the app.
IMPORTANT: If an inReach device is not connected or does not have a strong GPS signal while connected, you may need to enable location services on your phone. Waypoints created in the Earthmate app will not display on the inReach SE®.
iOS Instructions
Creating a Waypoint at Your Current GPS Position
  1. Open the Earthmate app, then:
    • From the Map page, touch Waypoint Flag.
      -or-
    • Select More > Waypoints, then touch Earthmate Plus Icon.
  2. Make desired changes to name, icon, and coordinates by tapping on the field.
  3. Select Done.
Creating a Waypoint at a Specific Position on the Map Page
  1. Open the Earthmate app.
  2. From the Map page, swipe on the map to pan, center, and zoom the map on the position to be marked.
    NOTE: See Related for instructions for downloading and managing maps in the Earthmate app.
  3. Touch the position to be marked on the map, then Lowercase i in a Blue Map Pin will appear:
    Blue Map Pin as it Appears on the Map
  4.  Tap Selected Location.
    Selected Location Word Bubble
  5. Select New Waypoint.
  6. Make desired changes to name, icon, and coordinates by tapping on the field.
  7. Press Done when finished.
Android Instructions
    • From the Map page, touch Three Dots, then select Mark Waypoint.
      -or-
    • Select Three Lines Menu Icon > Waypoints, then touch Waypoint Flag.
  3. Touch Back Arrow when finished and the waypoint will be saved.
  4. Tap Lowercase i in a Blue Map Pin.
  7. Touch Back Arrow when finished and the waypoint will be saved.
Related
