The Buttons on My Garmin Watch Do Not Respond When Pressed or Appear to Be Stuck
If a button on your watch stops working, it is possible that debris may be present between the button and the watch housing. As a first step to resolving this issue, thoroughly rinse your watch with fresh water.
I Rinsed My Watch but the Button Is Still Stuck
Stuck buttons after rinsing the watch may require you to follow the steps below to restore functionality.
Fill a small bowl with fresh water.
Place the watch in the bowl and allow to soak for 10 minutes.
Remove the watch from the bowl and rinse thoroughly under a low-pressure faucet.
Shake off the excess water and allow it to air dry completely.
For more information on cleaning a Garmin device, refer to the Device Care section of your owner's manual.
IMPORTANT: To avoid causing permanent damage to your device, follow the guidelines below.
Avoid extreme shock and harsh treatment, because it can degrade the life of the watch.
Do not use any sharp objects to clean the watch.
Avoid chemical cleaners and solvents that can damage plastic components and finishes.
