Vehicle Power Cable Damaged or Not Charging a Device
If your automotive device's vehicle power cable fails to provide a charge, make sure that the issue lies in the power cord and not in your vehicle's cigarette lighter outlet. If possible, try using your 12-volt adapter in a different cigarette lighter outlet, or a different vehicle.
If you continue to have charging issues, there may be a problem with your 12-volt adapter caused by one of the following:
