Changing the Track Color on the eTrex Touch 25, 35, or 35t
On the eTrex® Touch 25, 35, and 35t outdoor handhelds you can change the color of individual tracks. You can also change the default track color that is used for the current track.
NOTE: The eTrex Touch 25, 35, and 35t record files in an activity format (FIT) by default. If you need the handheld to also record files as tracks (GPX), select Power Button > Setup > Activities > Advanced Setup > Output Format > Tracks (GPX/FIT).
  1. Press Power Button to open the app drawer.
  2. Select Activity History or Track Manager.
  3. Select Current Activity, Current Track, or a saved activity or track.
    • Additional steps for archived tracks:
      1. Select Archived Tracks.
      2. Select an archived track.
      3. Select Lowercase i.
      4. Tap Gray Star.
      5. Select the saved track.
  4. Select Lowercase i.
  5. Select Color.
  6. Select the desired color.
  7. If necessary, select Show on Map to toggle this setting on.
