Instructions to Sync Deezer Content to the Enduro 2
This article will provide instructions to setup and sync Deezer music and podcasts to your Enduro™ 2 watch.
Requirements
The following are requirements to use the Deezer app with your watch:
  • The watch must be paired to your smartphone through the Garmin Connect™ app.
  • The watch must be set up to connect to a secure Wi-Fi network. For help, see - .
  • A Deezer Premium subscriptions is required. For help, see Deezer's website.
I Meet the Requirements. What Do I Do Next?
The three steps listed below need to be completed when first setting up the Deezer app with your watch. Once complete, you will only need to follow the third step when you want to load additional content to your watch. Select each section to expand and view instructions on completing each step:
Step 1: Download and Install the Deezer Connect IQ™ App
  1. Select the following link to download the app - Deezer Connect IQ app.
  2. Select Download.
  3. If prompted, sign in to your Garmin account.
  4. Select your watch to download the app.
  5. Acknowledge any app permission requests.
  6. Sync your watch:
    • To sync via Bluetooth: Be in range of your paired smartphone, press and hold Light to open the Controls Menu. Select blue sync arrows to Sync.
    • To sync via Wi-Fi: Be in range of your Wi-Fi network, press and hold Light to open the Controls Menu. Select blue sync arrows to Sync.
    • To sync using Garmin Express™ software:  Connect the watch using supplied power/data cable to the computer. Open Garmin Express program. A sync will start automatically once your watch is detected.
The Deezer app will now be installed to your watch.
Step 2: Set up the Deezer Connect IQ App
Your watch must be connected to your Wi-Fi network and your paired smartphone.
  1. On the watch, press and hold DOWN (the music shortcut key).
  2. Select Deezer.
    Optional: If you already have a music provider selected, press and hold UP/MENU then select Music Providers.
  3. The watch will display the message, Open Garmin Connect on Phone.
  4. Select Next.
  5. Your smartphone will ask you to sign in.
    Connect IQ Deezer Sign In
  6. Acknowledge the message on the phone which will take you to a Deezer sign in. Depending on whether you have an account, the login process will be as follows:
    • Existing Deezer users: Enter your login details and select login. From here, skip to Step 3.
    • New to Deezer: Select Register here, and follow the steps to create your account.
  7. If prompted, enter credit card details to complete the process.
Step 3: Selecting and Syncing Content to the Watch
From your Deezer account, create playlists or you can download existing playlists. For more information, see Make playlists or edit an existing Deezer playlist on Deezer Support.
  1. On the watch, press and hold Down (the music shortcut key).
  2. Press and hold Menu to access settings.
  3. Select Music Providers.
  4. Select Deezer.
  5. Select My Playlists.
  6. Select a playlist.
  7. Select Done.
  8. Press the BACK button and select Yes to Start music sync now?
At this point, the watch will attempt to connect to your Wi-Fi network. We recommend plugging the watch into a charger near the Wi-Fi router for the best results.
Related
